#1 Stanza strut swap Q
SNY120 Posted on: 2010/3/9 10:40
Simple question, I hope
Swapping in the (shortened) stanza bits into an 85 ute. The 2 bolts that hold the steering arm (knuckle) to the strut, does anyone know the size, length, pitch?
Or can I remove and reuse the ones that are in the 1200 struts?
Cheers,
Jake
#2 Re: Stanza strut swap Q
LittleFireyOne Posted on: 2010/3/9 10:47
Hmm, being a later ute I'd be inclined to think you can. I'm just trying to remember if my 77 120y was like that when I put the stanza struts in.
#3 Re: Stanza strut swap Q
PIGDOG Posted on: 2010/3/9 10:56
edit, so you have stanza steering arms in it and you just need the bolts?
original ones cant be reused as they are studs not bolts
#4 Re: Stanza strut swap Q
SNY120 Posted on: 2010/3/9 11:18
^ yep, stanza struts and steering arms. No visible means of joining the two.
I have no access to either of them (or the ute) at the mo, so I cant go have a look either.
PS New to datsuns, but not cars.
#5 Re: Stanza strut swap Q
PIGDOG Posted on: 2010/3/9 11:24
yeah they use bolts in the larger struts. they are the same size and pitch as the caliper bolts im pretty sure
easy enough to pull a caliper bolt out and test it. think the caliper bolts are longer though
#6 Re: Stanza strut swap Q
SNY120 Posted on: 2010/3/9 11:27
sweet, thanks mate.
