Oil pump leak suggestions? Dyno tomorrow... :/
Hi all,
The oil pump on my fresh rebuilt A14 engine has decided to leak...
I've tried everything I can think of from tightening the bolts to silastic-ing the oil pump>block gasket. I've even switched over the oil pump from my 1200 engine and same problem. I can't quite get a good look at it but it's def leaking from somewhere behind in between the block and filter, which then fills up the little lip in the filter with oil..
Any suggestions?? It's s'posed to be off to the dyno to get tuned tomorrow and now this happens! :/
Cheers,
Sam
Posted on: 2010/3/16 9:42
Edited by spraycanmansam on 2010/3/21 6:36:36
Subject Poster Date
     Oil pump leak suggestions? Dyno tomorrow... :/ spraycanmansam 2010/3/16 9:42
       Re: URGENT: Oil pump leak suggestions? Dyno tomorrow... :/ Fenix_Longbow 2010/3/16 9:48
         Re: URGENT: Oil pump leak suggestions? Dyno tomorrow... :/ ROConnor 2010/3/16 9:53
           Re: URGENT: Oil pump leak suggestions? Dyno tomorrow... :/ Fenix_Longbow 2010/3/16 10:02
             Re: URGENT: Oil pump leak suggestions? Dyno tomorrow... :/ ROConnor 2010/3/16 10:05
               Re: URGENT: Oil pump leak suggestions? Dyno tomorrow... :/ Fenix_Longbow 2010/3/16 10:22
               Re: URGENT: Oil pump leak suggestions? Dyno tomorrow... :/ ROConnor 2010/3/19 6:31
       Re: URGENT: Oil pump leak suggestions? Dyno tomorrow... :/ spraycanmansam 2010/3/18 5:42
       Re: URGENT: Oil pump leak suggestions? Dyno tomorrow... :/ spraycanmansam 2010/3/21 6:35
         Re: URGENT: Oil pump leak suggestions? Dyno tomorrow... :/ Dodgeman 2010/3/22 13:52
       Re: Oil pump leak suggestions? Dyno tomorrow... :/ ddgonzal 2010/3/21 16:22
