brake failure
Quite a regular
hey i am so close to geting my 1200 finished its not funny then the brakes decide to not work.
they are all drum brakes
first bled the brakes and noticed still not working. Nearly all thye brake cylinders were leaking fluid so they were all replaced. the rear shoes were worn down so i replaced those aswell and re-adjsted all the brakes and the handbrake. again bled the brakes till no air and still no brakes. we re-bled the brakes to make sure there is NO air in the brake lines. pulled the drums off and push the pedal and the shoes move and it all appears to be working but theres no pressure on the brake pedal once the drum is back on. if you pump the pedal a bit you start to feel pressure at the pedal but still not much. is this a master cylinder problem because thats about the only thing i havent eliminated fault with yet??? thaanks
Posted on: 2010/6/14 8:01
bloody oath
Subject Poster Date
     brake failure iowna1200ute 2010/6/14 8:01
       Re: brake failure clyons8 2010/6/14 8:11
       Re: brake failure ddgonzal 2010/6/14 8:12
         Re: brake failure iowna1200ute 2010/6/14 8:18
           Re: brake failure clyons8 2010/6/14 8:37
             Re: brake failure iowna1200ute 2010/6/14 8:53
               Re: brake failure clyons8 2010/6/14 9:01
       Re: brake failure ssskiwi 2010/6/14 9:10
         Re: brake failure iowna1200ute 2010/6/14 9:18
           Re: brake failure PIGDOG 2010/6/14 9:49
         Re: brake failure iowna1200ute 2010/6/22 1:44
       Re: brake failure clyons8 2010/6/22 1:55
         Re: brake failure iowna1200ute 2010/6/22 5:06
       Re: brake failure clyons8 2010/6/22 10:00
       Re: brake failure levey 2010/6/22 12:24
         Re: brake failure ssskiwi 2010/6/22 13:04
       Re: brake failure coxsteve 2010/6/22 13:47
         Re: brake failure iowna1200ute 2010/6/23 7:20
         Re: brake failure iowna1200ute 2010/6/24 10:33
           Re: brake failure DattoFrog 2010/6/24 13:10
