#1 Datsun 1200 bluebird strurt conversion pitman arm problem
brewskie Posted on: 2010/7/31 14:46
Good Day, new to this and after a little advice I have a 1200 ute which I purchases a full bluebird strut conversion for everything bolted up perfect except the tapered hole on the pitman arm is much smaller than the Bluebird one is there a different pitman arm I should run any help would be greatly appreciated Thanks Daniel
#2 Re: Datsun 1200 bluebird strurt conversion pitman arm problem
ddgonzal Posted on: 2010/8/1 1:14
You can have the hole machined bigger.
Do you mean a 910 Bluebird? 510 & 610 Bluebird setups will ruin the camber.
