Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Compound Turbo A Series
lamb_daiquiri
Posted on: 2010/10/1 22:57
Here's a wacky question. Has anyone attempted to compound turbo charge an A series engine? i.e. where you use two turbo chargers in series to achieve much higher boost pressures. If each turbo uses a pressure ratio or 2 then you et something like 45psi boost but the wide map of each turbo at a PR of 2. I read about this ages ago and wondered if anyone's tried it.
The downside is these systems tend to be a bit laggy having to spin up one turbo and then the next but some serious power could be extracted assuming the internals hold up. The upside is large boost and the opportunity to intercool twice and increase compression efficiency. Not sure if it's practical or not but it would be pretty cool to see a 400HP A series! It will be fun to see your responses!
#2
Re: Compound Turbo A Series
reuby_tuesday
Posted on: 2010/10/1 23:25
dont think it as been done to an a-series as far as I know.
The FD series RX7 used something like what you are talking about. Its a pretty complex setup rx7 wiki
#3
lamb_daiquiri
Posted on: 2010/10/1 23:35
Not totally sure but I think that was a sequential setup. I read about turbo compounding in book on turbocharging, I think it's been applied on larger diesel engines from memory. It would be a cool project.
#5
Posted on: 2010/10/2 2:56
In automobiles, it is used to extend/smooth the power band. Porsche 959 supercar was the first street car to do this.
In older designs (airplanes, diesels, etc.) it was used to get more boost as the available turbos were plenty limited. Today there are many turbo choices, so if you want high boost, you can just use a single turbo.
#6
lamb_daiquiri
Posted on: 2010/10/2 13:50
ddgonzal is on the money for what I mean.
#9
davidbil
Posted on: 2010/10/2 16:11
how about super turbo
suparcharge for the torque and then turbo charge for anything above 4000rpms
#10
Datsun100ATurbo
Posted on: 2010/10/2 16:46
A guy in Sweden mad a Opel Manta with both supercharger and turbo a few years ago, he used a Volvo engine like everybody else in Sweden.... they´ll put Volvo engines in anything.
An A-series with this setup would be awesome... http://www.youtube.com/watch?v=uqg4SVFYRVI http://www.youtube.com/watch?v=ZPDBPXEhd_0 You can view topic.
