Can I use a 56 clutch release lever with a 60 gearbox?
I want to swap my 56-series gearbox for a 60-series gearbox. As you know, the release levers are different:
But since we didn't get clutch cable gearboxes here, I only have a 56-series lever arm. What does it take to use it with the 60-series gearbox. Can I space out this clutch fork or will the cable adjust far enough?
jpg  56-series_release_lever.jpg (107.29 KB)
174_4fdf122542e8f.jpg 566X581 px
Posted on: 2012/6/18 12:33
Re: Can I use a 56 clutch release lever with a 60 gearbox?
another view
jpg  bearing_fork.jpg (38.14 KB)
174_4fdf1657bc7f1.jpg 560X352 px
Posted on: 2012/6/18 12:48
From Perth WA AUS
I think it would be OK DD, but not 100% sure.
Posted on: 2012/6/18 13:07
Datsun 1200 2Dr sedan.
Hi DD,
Sorry I should have posted some pics up, been a bit slack there.
What I found when I installed the 60 series box was that the 56 clutch fork is fine but we just couldn't get the clutch adjustment quite correct. The solution was to unbolt the pedestal that the lever pivots on and put 3 1.5 ( probably 2 would suffice ) washers in then bolt it back up to bring it out 5-6 mm and that did the trick nicely.
Cheers
Dave
Posted on: 2012/6/18 20:28
