Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Datsun offset
joker
Posted on: 2012/10/2 21:48
hey guys ive just bought a set of wheels from the US for my 1200 wagon. The backspace/offset is not as positive as a standard setup which i knew when buying them but what i was wanting to know is how can i bring the wheels in slightly? I know the rear will need the diff shortened to get them under properly but is there a way of bringing in the front? Does the disc brake setup bring them in? The wagon is all standard but low so any tips would be greatly appreciated
#2
Re: Datsun offset
supafatto
Posted on: 2012/10/2 22:02
Camber tops and adjustable lcas will bring the front in but doing this will reduce turning as the wheel may hit the inner guards
#3
Re: Datsun offset
Posted on: 2012/10/3 7:36
Standard 1200 offset is the same drum or disk setup.
As supafatto said, camber tops or adjustable LCA can be used to bring the tops of the wheel/tyre in via negative camber. Alternatively you can use overfender flares, or try Rolling the Gaurd You can view topic.
