a12 turbo buildup. advice needed
From Adelaide, Australia
Hey guys after a long time im finally building up my a12 turbo motor. I originally bought it carby turbo. Atm im replacing a few things. Im using a duropro gasket kit. Im not sure if the headgasket is good enough though? Im using a standard bottom end and a h89 head. the heads at the machinist getting faced, pressure tested and im using Stewart Wilkins double valve springs. I am also going to purchase arp head studs as well. I dont expect to reach 280hp but I am interested to see what I can get out of a pretty much standard a12/h89 combination. The carby turbo probably will go back on untill I can save some more for efi. Doee anyone have any advice or positive input? thought it might be a good idea to ask :p
Posted on: 2015/3/5 7:44
Subject Poster Date
     a12 turbo buildup. advice needed Matto1kUte 2015/3/5 7:44
       Re: a12 turbo buildup. advice needed sikyne 2015/3/5 9:56
         Re: a12 turbo buildup. advice needed Matto1kUte 2015/3/5 12:57
           Re: a12 turbo buildup. advice needed Matto1kUte 2015/3/5 14:17
             Re: a12 turbo buildup. advice needed BigD 2015/3/6 2:33
               Re: a12 turbo buildup. advice needed Matto1kUte 2015/3/6 5:06
       Re: a12 turbo buildup. advice needed Matto1kUte 2015/3/13 9:52
         Re: a12 turbo buildup. advice needed Dundee1000 2015/3/14 6:52
           Re: a12 turbo buildup. advice needed Matto1kUte 2015/3/14 14:24
