Clutch master cyliner - coupe
From Seattle ,WA.
can I still buy one new OE anywhere? I checked with Nissan on the part number from the wiki - 30610- something (doing from memory) the 2nd number as its the one that superceeds the original and Campbell Nissan (DD - you know who I mean) said NLA - not produced even after emailing nissan to try and order it.....any suggestions, Canadian maybe or AU perhaps???
Thanks, Evan
Posted on: 2015/4/17 5:34
Re: Clutch master cyliner - coupe
From Melbourne, Australia
can still buy 120y ones here - which suit fine
normally PBR brand - but i think that is an aussie brand
AUD$120 odd
maybe look up the part number for 120y and request at your brake shop?
Posted on: 2015/4/17 5:39
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Seattle ,WA.
i looked at 210 and 120 MC's but I think the 120 (B210 74-77) has mounts at like 10 and 4 o'clock vs. 12 and 6 for the coupe firewall....maybe i need to do more homework
Posted on: 2015/4/17 5:42
yeah, im not sure if it's a b210 that didnt have brake booster or something, because that would likely give the mounting difference you describe
i can look at part numbers etc if you like over the weekend
Posted on: 2015/4/17 5:45
1200 Coupe Rallycar
From Seattle ,WA.
thanks for the help, anys appreciated. I have to figure something out, I have no pedal pressure and no fluid leaking I can see so I assume its bypassing in the MC, i bought a new slave and wanted an MC, hopefully OE Nissan (Tokiko i think) but probably wont get that lucky....are rebuild kits available down under?
Posted on: 2015/4/17 5:49
Why not use one from a B310?
Posted on: 2015/4/17 6:11
They are really inexpensive now that they are on clearance.
http://www.stockwiseauto.com/product_ ... ssan/Model/1200/Year/1971
http://classicgarage.com/dab119clmacy.html
You can use a B210 unit if u shorten the rod
Posted on: 2015/4/17 6:22
From Seattle ,WA.
that what I couldn't remember - the shortening of the rod. Is the 310 one your showing from a "210" model car or the FT drive 310? I think the 1981 210 one I looked up at Oreilys had the off set ears for the mount.
thansk for the leads, you buy that coupe over there?
Posted on: 2015/4/17 6:27
From Seattle ,WA.
thanks David, just ordered one - $38 bucks shipped, cheap!
Mahalo!
Posted on: 2015/4/17 6:36
Good on ya.
Nah the B310 coupe was thoroughly beaten. There is a very nice 1200 sedan here I have my eye on. But I'm enjoying not owning a car.
Posted on: 2015/4/17 6:37
