EGI: Dropping resistor wiring
From Sydney, NSW
Hi All,
I can see in the diagram that each connector from the dropping resistor goes to an injector but just wondering where the BW wire then goes off to? I'm assuming 12v power but just wondering what kind of fuse I'd need etc or should it be run on a relay and through the ignition etc?
Posted on: 2015/7/3 1:29
Subject Poster Date
     EGI: Dropping resistor wiring thomen 2015/7/3 1:29
       Re: EGI: Dropping resistor wiring ddgonzal 2015/7/3 3:53
         Re: EGI: Dropping resistor wiring thomen 2015/7/3 4:26
           Re: EGI: Dropping resistor wiring ddgonzal 2015/7/3 7:10
             Re: EGI: Dropping resistor wiring thomen 2015/7/3 7:14
               Re: EGI: Dropping resistor wiring ddgonzal 2015/7/3 8:25
                 Re: EGI: Dropping resistor wiring ddgonzal 2015/7/4 9:19
                   Re: EGI: Dropping resistor wiring thomen 2015/7/13 3:36
                     Re: EGI: Dropping resistor wiring ddgonzal 2015/7/13 5:41
                 Re: EGI: Dropping resistor wiring thomen 2015/7/4 11:03
                   Re: EGI: Dropping resistor wiring ddgonzal 2015/7/4 11:24
       Re: EGI: Dropping resistor wiring thomen 2015/7/13 6:43
         Re: EGI: Dropping resistor wiring ddgonzal 2015/7/13 7:14
           Re: EGI: Dropping resistor wiring thomen 2015/7/13 7:20
             Re: EGI: Dropping resistor wiring ddgonzal 2015/7/13 7:39
               Re: EGI: Dropping resistor wiring thomen 2015/7/13 7:44
                 Re: EGI: Dropping resistor wiring ddgonzal 2015/7/13 8:17
           Re: EGI: Dropping resistor wiring ddgonzal 2015/7/13 7:23
       Re: EGI: Dropping resistor wiring ddgonzal 2015/8/8 8:42
