Wiring help! Swapped a14 into 1200
I need some pictures of a a14 swap into a 1200. Basically I need pictures of the wires that go to the started and alternator. I've extended the wires to the alternator. Just need to see where everything else goes. Also the a14 I swapped in has electronic ignition.
Posted on: 2016/4/30 3:31
Subject Poster Date
     Wiring help! Swapped a14 into 1200 72BRE110 2016/4/30 3:31
       Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/4/30 4:14
         Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/4/30 4:54
       Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/4/30 4:54
         Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/4/30 5:36
         Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/4/30 5:48
           Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/4/30 6:18
             Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/4/30 6:21
               Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/4/30 6:43
               Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/4/30 6:56
           Alternator wiring - Swapped HLB210 A14 into 1200 ddgonzal 2016/4/30 11:12
       Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/5/1 2:41
         Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/5/1 3:28
           Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/5/1 4:07
             Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/5/1 4:11
               Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/5/1 5:01
                 Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/5/1 5:12
                   Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/5/1 5:30
                     Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/5/1 5:55
       Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/5/6 1:55
         Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/5/6 1:57
           Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/5/6 5:34
             Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/5/6 8:26
       Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/5/6 9:37
         Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/5/6 10:31
       Re: Wiring help! Swapped a14 into 1200 72BRE110 2016/5/7 2:38
         Re: Wiring help! Swapped a14 into 1200 ddgonzal 2016/5/7 5:08
