Cowl Rubber around wiper pivot
From Sydney, Australia
Hi All
Is anyone able to tell me where or even the name of the rubber part
Sits between cowl and plenum, water box area
Sealing around the hole where wiper pivot arm comes through the cowl
Checked the wiki, and not able to find a source to purchase new ones
I have one used one
Would like to get two new ones
Cheers
Posted on: 2018/11/17 11:43
Re: Cowl Rubber around wiper pivot
From Creswell, Oregon USA
Posted on: 2018/11/17 11:46
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Hey, thanks for reply
They are the wiper pivot rubbers
The ones I'm looking for are larger
They fill the gap between the cowl lower side and the plenum around the outside of wiper pivot
To get them in or out the wiper pivot must be removed
Then the rubber can be collapsed a little and eased out
I've not seen them anywhere apart from the one I had in one side
Posted on: 2018/11/17 11:53
Sorry I haven't got a picture right now
But to try explain
They are a cylinder type shape, probably about 2mm thick wall
Perhaps 32-35mm diameter
The bottom end is cut square with the cylinder shape and a small notch cut out to sit over one of the nuts for wiper pivot bolt
The top side that goes to underside of cowl, is cut on an angle to the cylinder
To match the profile of cowl
I'm thinking I might have to make my own with some suitable sized black rubber tubing and a razor blade
Posted on: 2018/11/17 12:01
Posted on: 2018/11/17 12:18
Parler @MDMachine
Hmm. That particular picture
Looks like it may be missing the rubber part I'm trying to describe
Posted on: 2018/11/17 12:50
From Castro Valley,CA USA
Posted on: 2018/11/17 18:55
Hmmm ... maybe what he is describing is not stock?
These are the only factory ones that seal "around the hole where wiper pivot arm comes through the cowl"
Wiper Part Numbers
28876-H1000 SEAL-PIVOT WINDSHIELD WIPER (2 needed)
They are different than the "rubber boots" discussed above
Brojects sells them $10
jpg  28876-H1000.jpg (117.21 KB)
174_5bf138807b46c.jpg 1080X1080 px
jpg  28876-H1000_.jpg (113.99 KB)
174_5bf1388be1bd0.jpg 1080X1080 px
jpg  28876-H1000-.jpg (117.07 KB)
174_5bf138968f7c3.jpg 1080X1080 px
Posted on: 2018/11/18 9:56
Edited by ddgonzal on 2018/11/18 10:13:09
Sorry for the delay in response
You could be right with not standard
Trying to attach a picture of what I have
I’ve tried 3 different iPhone photo resize apps so far
Posted on: 2018/11/19 9:40
You can post a photo to a photo site, then post a link here
Or resize the photo to 800x600 it'll Upload for sure
Posted on: 2018/11/19 9:53
