attempt to dispell su myth
From Charlotte NC USA
there are some common miss conceptions when it comes to the su. I will try to settle them. weber guys please dont flame me, they have their uses 3-9000 rpm,I am only trying to inform not slam.
Ok here goes,
1: they don't produce power.
have you driven a stock 1200 lately the stock down draft chokes the engine down to the 60 or so H.P. they make.
2:they are hard to tune
again not so. there is a system to tuning an su. once learned you can tune a new set in minutes flat.
3: they are not reliable.
HELLO nissan, jaguar, triumph, rover, and tvr would not put these on anything if they were not reliable.
4: fuel milage will tank.
again not true if tuned properly and driven reasonably they will equall or beter the stock setup.
e.g. I have a datsun 1600 wagon with a 2100cc L-20 and 38mm su's I get between 29-32mpg that is a US gallon.
I hope that this has helped out some
I am aware that the weber is the ticket for top power, but how often do you drive around town at 5000 rpm honestly!
Phil
su owner since 1990
Posted on: 2003/5/3 11:03
Subject Poster Date
     attempt to dispell su myth nutcase 2003/5/3 11:03
       Re: attempt to dispell su myth ddgonzal 2003/5/3 12:34
       Re: attempt to dispell su myth ang94541 2003/5/3 23:10
       Re: attempt to dispell su myth converted 2003/5/4 3:26
         Re: attempt to dispell su myth Demojob 2003/5/4 3:59
           Re: attempt to dispell su myth rally-a-coupe 2003/5/4 9:14
