Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
5 speed box
dattyfan
Posted on: 2000/6/4 3:09
can anyone tell me if the 5 speed gearbox from a B310 model will fit a B110 and what mods are needed? (the box is the
dog-leg shift pattern) Thanks.
#2
Re: 5 speed box
Rain_Master_Jr
Posted on: 2000/6/4 5:22
Uhm, Here in the US, the 310 is front wheel drive.. That'd take quite a
few mods.. ;)
#3
Re: 5 speed box
stirlingmac
Posted on: 2000/6/5 7:12
Don't quote me cause without model numbers etc I could be wrong, but the dogleg 5 speed should be the same length overall as the 4 speed. So your driveshaft won't need altering. But the
input spline may be larger in Dia and will need a clutch plate from an L series engined car like a 1600.which I think has a similar dia clutch plate, or if they are available in the UK use the FWD Pulsar 1.5 EXA Turbo clutch and pressure plate for a bulletproof set up. The only problem you may experience is the reversing light switch hitting the tunnel, a good whack with a hammer should fix that. The crossmember is easily fabricated though Nissan years ago listed one in their Motorsports manual it would be hard to find one. Various 1200 models came equipped with the 5 speeds factory so it's a fairly straight forward job.
#4
Re: 5 speed box
ratdat_uk
Posted on: 2000/6/5 7:56
The Pulsar EXA wasn't sold here in the UK (although there are a few here) but if the EXA has the E15ET then it would be the same a an N12 Cherry Turbo. BTW if you need a
5speed I know somebody that has a couple of brand new ones.
#5
Re: 5 speed box
mareospeedwagon
Posted on: 2000/6/5 8:28
When I put the dog-leg 5-speed into my 1200, I had to get a driveshaft from an automatic tranny.
The drive shaft splines on the dog-leg 5-speed is the same as an automatic tranny if you can find one. Unlike most driveshafts that have replacable U-joints and therefore the front yoke is replacable, the 1200 U-joints are not replacable, they are welded. The dog-leg 5-speed is a heavy duty trans and produces more friction and uses more of your horsepower that the regular 5-speed or 4-speed, although the most think the tranny is worth it. You get nothing for free, you have to trade HP for better reliability. I think the 4-speed was very reliable. I put over 200,000 miles on mine and never had any problems. I still have the 4-speed if anyone needs it. I also have a 4-speed with fewer miles on it.
#6
Re: 5 speed box
dattyfan
Posted on: 2000/6/5 6:18
Helo Eddie,
I assume you mean Will that has the new box. Thats where it started!! Do you know anyone with a "normal" pattern 5 speed box for sale? See you at Billing. Mike Chorlton.
#7
Re: 5 speed box
bloxhamd
Posted on: 2000/6/6 1:04
What year is the B310? The '79 to '81 B310 is called a "Datsun 210" in North America. They are RWD. I have an '81 'B310' RWD 5spd in my 1200. The rear trans. mount had to
be changed. I actually used a rear mount off an auto model & reversed it fora good fit. I also needed the auto driveshaft, which was the correct length. Hope this helps.
#8
Re: 5 speed box
ratdat_uk
Posted on: 2000/6/6 5:33
Mike,
Aren't all the normal shift pattern boxes longer, though? I use the dogleg box in my other Datsuns an really like it now I'm used to it. Are you still looking for sill trims? Eddie.
#9
Re: 5 speed box
dattyfan
Posted on: 2000/6/6 3:08
Eddie,
Got the sill trims now thanks. I'm not sure about what box will fit and what mods are needed, I just need a 5th gear!. I would appreciate any advice you can give me.Thanks. Mike. You can view topic.
