Hummour
A lot of datsun owners can probably relate to the definitions.USES FOR TOOLS
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive car parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing convertible tops or tonneau
covers.
ELECTRIC HAND DRILL: Normally used for spinning steel pop rivets in their holes until you die of old age, but it also works great for drilling rollbar mounting holes in the floor of a sports
sedan just above the brake line that goes to the rear wheel cylinders.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Quija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its
course, the more dismal your future becomes.
VICE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETELENE TORCH: Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the socket drawer (what wife would think to look in_there_?) because you
can never remember to buy lighter fluid for the Zippo lighter you got from the PX at Fort Campbell.
ZIPPO LIGHTER: See oxyacetelene torch.
Posted on: 2000/7/1 2:17
Subject Poster Date
     Hummour chris_stam 2000/7/1 2:17
