FS. 1978 or later 120y struts with PBR Brakes
From Brisbane, Narangba
For Sale- 120y stuts with the PBR calipers fitted. Same size disc and a 1200 but with larger caliper for marginally better stopping power. Fitted with brand new Monroe Gt gas strut inserts and brand new Ferodo brake pads. Strut inserts have done less than 3000kms and pads less than 1500kms. Disc is in excellent condition, no machining required, wheel bearing recently repacked. Bolt in and drive away.
Asking $250 ono due to the fact of the new inserts and pads. Only selling due to upgrade.
Contact= 0408335353 or email or pm me.
Daniel
Posted on: 2005/11/21 11:53
Re: FS. 1978 or later 120y struts with PBR Brakes
Quite a regular
From south brisbane
what else would i need to fit them to a 83 1200 ute with drums. i am really keen to do a brake upgrade
thanks
Posted on: 2005/11/22 9:57
Just bolt them in. Possibly castor rods. Someone else will have to specify that. I will supply them with the struts if need be and a twin brake master cyl if it doesnt already have one. I have one of those too in good order that you can have for $20. Just bolt in and drive.
Posted on: 2005/11/22 11:02
Just put 1200 springs and sping tops on and they bolt strait in. These are the best brakes that fit under 12 inch rims(coupe rims)!!!
I have a set on my sedan at the moment i use the 120y booster as well,but you only need the twin master to run them.
This is cheap as it cost me $150 just to rebuild the brakes.
Posted on: 2005/11/22 11:30
