Datsun 1200 ute ca18 conversion.. needs some work
Ok i have a 1980 datsun 1200 ute with a ca18det conversion. motor is healthy an starts an runs fine. is modplated for QLD.
i added photos of everything but they didnt upload. send me a txt an ill forward some to you until i work this out.
$3000 MAKE AN OFFER I WANT THIS GONE!!
0401884087
I bought it as a project and planned on getting the body straight and painting it.
i began some mods but lost interest about 2weeks into it.
Bought a garrett GT28R dual ballbearing turbo, a 450x300x76 front mount cooler (brand new), 3" piping and all silicone joints. a HKS mushroom pod filter (brand new).
I took the manifold off and have assembled the manifold an GT28R an dump pipe, but have not fitted. Has a braided oil return as well.
3" front turbo fitting (the bolt on part that your intake goes on). Plsnned on putting the AFM in the cooler piping. intake side of piping is done, just needs the turbo mounted up an the turbo side piping to be completed which is a small piece of straight 3".
Car will come with a box of new piping and silicone joints an clamps. the stock t25, 2 brand new in box Apex'i boost and water temp gauges with sensors, cooler is mounted, gt28r is ready to be bolted back on just needs an oil feed, the dash wiring is pulled apart, its all there just needs to be rewired, if you know dattos you wont have any dramas.
It has been in primer since i bought it about 2 months ago, havent had a chance to start any body work, inside tub has rust in it, there are a few small bits of rust here and there. can point them out if you come to have a look. has a locked diff. I drove it home from Redcliffe to cleveland no dramas, no headlights, indicators or windscreen wipes, thats what needs to be wired up an itll be good to go.
CHASING $3000 which is what i paid minus the GT28R and front mount and all piping.
Good base for a project.
Located in CLEVELAND, BRISBANE.
Contact me on 0401884087
Posted on: 2012/3/22 9:38
Subject Poster Date
     Datsun 1200 ute ca18 conversion.. needs some work JZD30 2012/3/22 9:38
       Re: Datsun 1200 ute ca18 conversion.. needs some work JZD30 2012/3/28 7:13
         Re: Datsun 1200 ute ca18 conversion.. needs some work tommo73 2012/3/29 3:07
       Re: Datsun 1200 ute ca18 conversion.. needs some work dat_lover 2012/3/30 5:15
         Re: Datsun 1200 ute ca18 conversion.. needs some work tommo73 2012/4/2 0:26
