Browsing this Thread:
1 Anonymous Users
I'm back and now retired |
From Mordialloc Victoria 3195
Hey lads. Getting back into playing with my Datto's. Coupe - Just Tweeked the timing a little and balanced the carbs. O2 was showing in running a little lean at the top end so upped the main jets and wow it loves to rev to 7500 now.
Ute - seem to have developed a serious ignition chop when it comes on boost so that will take a bit more investigation.
Clubman 7 - Its running sweet after I changed 'A LOT' - ( Haltec ECU, fuel pump, regulator,injectors ,added crank angle sensor - all new dyno map ) 148kw in a 550kg car is freekin awsome.
dp
Posted on: 2023/8/28 11:23
'79 B120 ute(TURBO EFI A15 + 60 ser.5spd ) '83 Clubman 7 ( TURBO EFI A15 + 63 ser.dog 5spd ) '73 KB110 Coupe Mild A15 5spd ( Quad carb revver soon) keep it simple
