#1 1200 brake conversion to r32 type
andoa Posted on: 2008/9/11 13:29
what do i need to do to fit this r32 gtst break set up i have? will it work?
#2 Re: 1200 brake conversion to r32 type
datsunsunny Posted on: 2008/9/11 16:12
you will need r32 callipers 280 mm diameter. 4 discs depending if ur using 4 stud use r31 disk if 5 stud use r32 disk. u need a 15/16 master cylinder using the same vacum assistant as long as i know.
then u need to make plates where the callipers will be attached to and replace your own plates that are holding the existing caliper.
if anyone can correct me on this statement pls do so.
#3 Re: 1200 brake conversion to r32 type
PIGDOG Posted on: 2008/9/12 0:23
this is how ive done it
200b struts
r32 gtst calipers
r33 discs
adaptor plate to bolt calipers to the strut
also think you need to run 200b steering arms instead of stanza otherwise the disc will hit the balljoint
need to bore out the centre hole in the disc and drill 4 new holes to that it can bolt to the back of the hub
lots of pics in my photo album
but this info isnt really valid if your not using aussie 200b struts
