Steveo's 1000 2-door sedan
From newcastle, NSW
i thought i would start a project thread of my 1k. Its been sitting out in the weather for the past couple of months so the paint has faded quite a bit needs body work but theres no rust and needs brake upgrade and a 'beefy rearend'!
And this is a close up of the turbo A14
I'll post some more pics as i get more done.
Feel free to leave your comments and suggestions.
Posted on: 2008/11/20 11:22
Re: Steveo's 1000 2-door sedan
From Darwin NT
i have a complete but pulled apart 1200 ute diff (h165) with series one bluebird discs on it ready to bolt into a 1000 (mounts modified to suit 1000 but not shortened) would be ideal for this project but the only issue i found was that with the wagon the little nipple and brake line may foul on the chassis rail but if its a race car i spose it wouldnt matter if you cut the chassis and made little reliefs for this and it the centre has been welded so its now fully locked
if your intrested find me a bluebird drum brake h165 and ill hapily swap you
and this will increase your track on the rear by 40mm either side (total of 80mm overall) which would be good as the front would also be wider if you go with berts front brake setup for the front
Posted on: 2008/11/20 11:35
current project 4x4 patrol...
From newcastle, NSW
So you have a ute diff with disks on it? Very interesting! belive it or not i've already got a bluebird diff sitting here, not sure if its series 1,2 0r 3? i don't know what condition the diff is in, i'll crack it open an have look, i'll get back to you!
I was looking into getting the diff i got shortened to fit under the 1K
Posted on: 2008/11/20 12:03
From Darwin NT
yeh im deifainlty intrested!
to tell if its h190 or h165 count the bolt holes for the centre
8=h165
10=h190
Posted on: 2008/11/20 12:05
From newcastle, NSW
Took the H145 apart today, and this is what i discovered.............
It was a dogs breakfast inside the housing! as you could imagine.
This is the 3rd diff i've been through so i'm going to upgrade H165 or H190 depending on what i can find it'll be a bluebird diff either way, i have a H165 already but it stuffed, thats why it was given to me.
I saw something similar to this in the random picture box, i think it was Lagwagon who posted it, but i could be wrong
Posted on: 2008/11/22 7:13
