#1 how wide can i go in the rear of my 1200 ute? (tyres)
ANGE Posted on: 2006/3/5 12:24
ok guys.. calder drag day is coming.. and im tempted to do a 'pre-engine rebuild quatermile pass' for comparison..
been looking on ebay for some sizeable tyres to fit under the rear of my ute..
im running 195/50/15 tyres on it atm which i know is probably nearly as wide as i can go as it is.. but i dont really wanna fry my good tyres too much so im looking for a pair to slap on for racing fun..
and if im gonna have a spare pair they might aswell be as big as i can get..
so to those who have tried whats the biggest i can get under there without sacraficing paint from my guards?
i know wheel offset is a factor so whats the ideal wheel or offset to use to fit the widest tyres?
thanks in advance
#2 Re: how wide can i go in the rear of my 1200 ute? (tyres)
Posted on: 2006/3/5 22:30
just go get some coomodore 195/65 or 70 r15's and have some fun... the 65 should clear your tubs and the taller profile will benefit your top speed... but kill your lower end a bit. greater rotational area.
#3 Re: how wide can i go in the rear of my 1200 ute? (tyres)
ANGE Posted on: 2006/3/6 10:39
how would i go fitting 205's or 215's in?
#4 Re: how wide can i go in the rear of my 1200 ute? (tyres)
Posted on: 2006/3/7 3:37
depends on wheel offset and also the diff you now have... its slightly wider isnt it?
#5 Re: how wide can i go in the rear of my 1200 ute? (tyres)
DVLDAT Posted on: 2006/3/7 4:47
225-235 if u move your mounts in i run 225's all day with no scrubage tiny bit of scrub with 235's
standard rear spring max is 205's hello wheelspin
#6 Re: how wide can i go in the rear of my 1200 ute? (tyres)
fat_dat Posted on: 2006/3/7 4:50
if you did a mini-tub what size tyres could you fit under there?
#7 Re: how wide can i go in the rear of my 1200 ute? (tyres)
ANGE Posted on: 2006/3/7 5:47
i have a hilux diff which has been shortened to the standard width... so 205's then?
#8 Re: how wide can i go in the rear of my 1200 ute? (tyres)
MadTimo Posted on: 2006/3/7 8:03
If you're only getting them for drags, get a higher profile, like 60's or 65's.
A) because they'll be cheaper, and
B) because they'll give you more traction when you let the air pressure down
#9 Re: how wide can i go in the rear of my 1200 ute? (tyres)
cadet1200 Posted on: 2006/3/7 8:20
Yeah I ran 205/50/15's on my previous datto ute. They were on TRX rims and went very close to rubbing on the springs.
You wouldn't get any wider without either using wheel spacers or going to the trouble of re-locating your spring perches. Unless of course Lag's old diff is a little shorter than a standard H165?
#10 Re: how wide can i go in the rear of my 1200 ute? (tyres)
12OOU Posted on: 2006/3/7 8:48
I'm the same as DVLDAT
