« 1 (2)
#11 Re: Gasket or not?
B210sleeper Posted on: 2006/5/16 0:16
Luckily, I have some good hot rod shops in the area, and was able to find the right gasket material fairly easily.
I hear that. Being right down the street from a hydraulic supply place has saved me many times. We also have a metric aircraft hardware place nearby too ;)
#12 Re: Gasket or not?
Ronald Posted on: 2006/5/16 9:56
copper "loctite" is a good thing to put on exhausts joints. its meant to stand up to the heatand if you put a bit of that on each side of the gasket then you should be home and hosed.
#13 Re: Gasket or not?
Mildman Posted on: 2006/5/16 12:20
You mean the copper spray called Hylomar? The stuff you spray on head gaskets?
#14 Re: Gasket or not?
Ronald Posted on: 2006/5/16 12:29
dunno, the stuff i've seen comes in a tube that you squeeze out and smear on. could be the same stuff
#15 Re: Gasket or not?
B210sleeper Posted on: 2006/5/16 20:54
if it's not specifically for use in a high temp exhaust enviroment it's a bad choice, and that copper stuff is for use with a gasket, like ahead gasket.
if you just use the exhaust gasket material it'll work fine.
#16 Re: Gasket or not?
Duncan Posted on: 2006/5/17 0:18
#17 Re: Gasket or not?
Duncan Posted on: 2006/5/17 0:20
It could use a bit more trimming, but here's the gasket I made for this.
The metal in between the gasket material is fairly thick, and I think it'll be fine as is. I'm not going to put any sealer on it at all.
#18 Re: Gasket or not?
Duncan Posted on: 2006/5/17 0:22
I went to edit my reply and somehow this got double posted? Oh well. Hopefully the exhaust problem is solved. Sorry about the double post.
#19 Re: Gasket or not?
B210sleeper Posted on: 2006/5/17 0:31
you probably don't need to trim it, but if you wish
« 1 (2)
