Re: how much coill to cut of a spring to lower 3 inches.
I'd guess 1/2 coil. Probably best to cut 1/4 or 1/8 coil at a time, then check. This is a time-honered acceptable way to lower cars with non-tapering coil springs.
Yes, the ride won't smooth out, but if the idea is to lower the car, this will work. You might end up with little to no suspension travel however, and this is a bad thing. 3 inches is a lot, maybe too much for the 610? How much travel is there now (like when the wheel bounces up going over a bump)?
The "lowered springs" are probably higher rate springs, making the car ride rougher, but less likely to bottom out due to stiffer springs ... is that what you guys are talking about?
Posted on: 2003/1/1 7:19
Subject Poster Date
     how much coill to cut of a spring to lower 3 inches. jaimecidpedro 2003/1/1 1:00
       Re: how much coill to cut of a spring to lower 3 inches. Lobster 2003/1/1 3:06
       Re: how much coill to cut of a spring to lower 3 inches. mikali 2003/1/1 5:13
         Re: how much coill to cut of a spring to lower 3 inches. ddgonzal 2003/1/1 7:19
           Re: how much coill to cut of a spring to lower 3 inches. 1200rallycar 2003/1/1 10:57
             Re: how much coill to cut of a spring to lower 3 inches. dimlight65 2003/1/2 16:33
           Re: how much coill to cut of a spring to lower 3 inches. jaimecidpedro 2003/1/2 3:22
             Re: how much coill to cut of a spring to lower 3 inches. ang94541 2003/1/2 9:42
               Re: how much coill to cut of a spring to lower 3 inches. dattodude 2003/1/2 10:49
                 Re: how much coill to cut of a spring to lower 3 inches. dimlight65 2003/1/2 16:23
                   Re: how much coill to cut of a spring to lower 3 inches. olboy 2003/1/25 7:49
       Re: how much coill to cut of a spring to lower 3 inches. bent_axel_bob 2003/1/25 4:00
       Re: how much coill to cut of a spring to lower 3 inches. Mawler1 2003/1/26 14:31
         Re: how much coill to cut of a spring to lower 3 inches. cfwase 2003/1/27 0:28
           Re: how much coill to cut of a spring to lower 3 inches. datto_dave 2003/1/27 1:04
             Re: how much coill to cut of a spring to lower 3 inches. ddgonzal 2003/1/27 2:03
               Re: how much coill to cut of a spring to lower 3 inches. 1200rallycar 2003/1/27 2:28
                 Re: how much coill to cut of a spring to lower 3 inches. ddgonzal 2003/1/27 4:35
                 Re: how much coill to cut of a spring to lower 3 inches. jaimecidpedro 2003/1/27 7:57
                   Re: how much coill to cut of a spring to lower 3 inches. ddgonzal 2003/1/27 8:35
                     Re: how much coill to cut of a spring to lower 3 inches. Matt 2003/1/27 10:24
                       Re: how much coill to cut of a spring to lower 3 inches. stirlingmac 2003/1/27 11:09
                         Re: how much coill to cut of a spring to lower 3 inches. datto_dave 2003/1/29 6:20
                     Re: how much coill to cut of a spring to lower 3 inches. ddgonzal 2003/4/6 19:38
                       Re: how much coill to cut of a spring to lower 3 inches. no 2003/5/17 4:28
