Re: Stock A12-A15 Turbo project, parts needed please??
Thanks for the info 1200rallycar, I think 10lbs would be max for what im trying to achieve I would start with maybe 6 and tune it from there and see how I go?? Im trying for something with little lag and reasonable throttle response.
Im going to use the carbie in the same fashion as I have with my car, its simple and easy...
I will hunt around for a turbo and go from there, if someone knows where I can get one that would be greatly appreciated Quote:
1200rallycar wrote:
i run two diahatsu charade turbos on an a14, have also used to on an a12 and a15 before
with the two i get full boost before 3000rpm and had upto 15psi without mucking around with wastegate acctuators, never heated them up either (the problem is keeping the boost down now so i dont blow too many motors) im using stock internal motors, blow thru turbo setup through intercooler into factory injection, we should catch up, im in ringwood area
its possible one would be ok for 10psi or less application (read: stock internal motor)
just had one rebuilt, cost $300
gettig another done atm
Posted on: 2006/9/1 1:42
Subject Poster Date
     Stock A12 Turbo project... Topgear 2006/8/31 17:01
       Re: Stock A12-A15 Turbo project, parts needed please?? OctaneR 2006/8/31 20:35
         Re: Stock A12-A15 Turbo project, parts needed please?? 140Z 2007/3/9 15:24
           Re: Stock A12-A15 Turbo project, parts needed please?? cheater_5 2008/6/30 6:57
             Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2008/6/30 9:34
               Re: Stock A12-A15 Turbo project, parts needed please?? cheater_5 2008/6/30 9:45
                 Re: Stock A12-A15 Turbo project, parts needed please?? BigV 2008/6/30 22:55
       Re: Stock A12-A15 Turbo project, parts needed please?? sidedraught 2006/8/31 22:57
         Re: Stock A12-A15 Turbo project, parts needed please?? 1200rallycar 2006/9/1 0:07
           Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/1 1:42
             Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/1 2:54
               Re: Stock A12-A15 Turbo project, parts needed please?? 3Rotor 2006/9/1 7:16
                 Re: Stock A12-A15 Turbo project, parts needed please?? Anonymous 2006/9/1 9:24
                   Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/1 14:24
                     Re: Stock A12-A15 Turbo project, parts needed please?? mad120y 2006/9/1 15:24
                       Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/1 15:45
                         Re: Stock A12-A15 Turbo project, parts needed please?? tappet 2006/9/1 22:49
                           Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/2 3:06
                             Re: Stock A12-A15 Turbo project, parts needed please?? dog160 2006/9/2 3:42
                               Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/2 7:48
                                 Re: Stock A12-A15 Turbo project, parts needed please?? 2QK4U 2006/9/2 8:54
                                   Re: Stock A12-A15 Turbo project, parts needed please?? matty 2006/9/2 9:17
                                     Re: Stock A12-A15 Turbo project, parts needed please?? R-fastmotorsport 2006/9/2 11:56
                                 Re: Stock A12-A15 Turbo project, parts needed please?? Dodgeman 2006/9/2 13:36
                                   Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/2 14:44
                                     Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/2 14:48
                                       Re: Stock A12-A15 Turbo project, parts needed please?? Turboute 2006/9/2 22:42
                                         Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/3 2:39
                                           Re: Stock A12-A15 Turbo project, parts needed please?? Turboute 2006/9/3 2:51
                                             Re: Stock A12-A15 Turbo project, parts needed please?? Turboute 2006/9/3 4:15
                                               Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/4 13:52
                                                 Re: Stock A12-A15 Turbo project, parts needed please?? ArJay72 2006/9/12 14:20
                                                 Re: Stock A12-A15 Turbo project, parts needed please?? kululadotgroen 2006/9/12 14:42
                                                   Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/13 1:15
                                                     Re: Stock A12-A15 Turbo project, parts needed please?? L18_B110 2006/9/13 1:54
                                                       Re: Stock A12-A15 Turbo project, parts needed please?? BigV 2006/9/13 2:12
                                                       Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/13 2:50
                                                         Re: Stock A12-A15 Turbo project, parts needed please?? L18_B110 2006/9/13 10:16
                                                           Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/13 13:03
                                                             Re: Stock A12-A15 Turbo project, parts needed please?? cheater_5 2006/9/13 21:00
                                                               Re: Stock A12-A15 Turbo project, parts needed please?? L18_B110 2006/9/14 1:43
                         Re: Stock A12-A15 Turbo project, parts needed please?? mad120y 2006/9/2 1:03
                     Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/1 15:32
         Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/1 1:22
         Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/8 15:25
           Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/12 8:13
             Re: Stock A12-A15 Turbo project, parts needed please?? cheater_5 2006/9/12 8:39
               Re: Stock A12-A15 Turbo project, parts needed please?? datto1000wagon 2006/9/12 10:16
               Re: Stock A12-A15 Turbo project, parts needed please?? Topgear 2006/9/13 2:55
       Re: Stock A12 Turbo project... B110SSS 2006/9/13 5:08
         Re: Stock A12 Turbo project... Topgear 2006/9/13 7:54
           Re: Stock A12 Turbo project... B110SSS 2006/9/14 4:15
             Re: Stock A12 Turbo project... Topgear 2006/10/3 13:34
               Re: Stock A12 Turbo project... sundat1200 2006/10/3 19:55
                 Re: Stock A12 Turbo project... Tyrie 2006/10/4 0:36
                   Re: Stock A12 Turbo project... Tyrie 2006/10/4 0:39
                     Re: Stock A12 Turbo project... A14force 2008/6/30 8:29
               Re: Stock A12 Turbo project... cheater_5 2006/10/4 1:39
                 Re: Stock A12 Turbo project... Topgear 2007/3/8 0:51
                   Re: Stock A12 Turbo project... Topgear 2007/3/8 1:51
                     Re: Stock A12 Turbo project... sikdatto1200 2007/3/8 18:12
       Re: Stock A12 Turbo project... D 2010/11/18 23:51
       Re: Stock A12 Turbo project... Dundee1000 2010/11/19 3:05
