Re: Brakes/Struts into 1200 Ute
From Burpengary
well i'm not sure, i remember reading somewhere that it's possible to just drill out some more holes 10mm on my current crossmember. is this true? if it is i'll just do that, otherwise i'll just want new arms asap.
so are you also saying that i'd be able to use 'the larger nissan struts' as in R31 and the like?
Posted on: 2007/9/26 8:24
Subject Poster Date
     Brakes/Struts into 1200 Ute lowendtheory 2007/9/23 10:57
       Re: Brakes/Struts into 1200 Ute sssute 2007/9/23 12:44
         Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/23 13:10
           Re: Brakes/Struts into 1200 Ute Team_Dat 2007/9/23 16:05
       Re: Brakes/Struts into 1200 Ute bobthebuilder 2007/9/24 2:53
         Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/24 5:41
           Re: Brakes/Struts into 1200 Ute bobthebuilder 2007/9/24 6:24
             Re: Brakes/Struts into 1200 Ute crzy_1200_ute 2007/9/24 7:42
               Re: Brakes/Struts into 1200 Ute lethal_john 2007/9/24 8:33
       Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/24 13:59
         Re: Brakes/Struts into 1200 Ute WhiteSedan 2007/9/24 14:31
           Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/24 15:02
             Re: Brakes/Struts into 1200 Ute WhiteSedan 2007/9/24 15:30
               Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/24 23:44
                 Re: Brakes/Struts into 1200 Ute lowendtheory 2007/9/25 11:54
                   Re: Brakes/Struts into 1200 Ute WhiteSedan 2007/9/25 12:01
                     Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/25 13:42
                       Re: Brakes/Struts into 1200 Ute lowendtheory 2007/9/26 8:24
                         Re: Brakes/Struts into 1200 Ute WhiteSedan 2007/9/26 8:33
                           Re: Brakes/Struts into 1200 Ute bobthebuilder 2007/9/26 10:06
                             Re: Brakes/Struts into 1200 Ute lowendtheory 2007/9/27 9:31
                               Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/27 11:24
                                 Re: Brakes/Struts into 1200 Ute WhiteSedan 2007/9/27 11:47
                                   Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/27 11:59
                                     Re: Brakes/Struts into 1200 Ute lowendtheory 2007/9/27 14:04
                                       Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/28 1:16
                                         Re: Brakes/Struts into 1200 Ute Trav 2007/9/28 2:29
                                           Re: Brakes/Struts into 1200 Ute Trav 2007/9/28 3:23
                                             Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/28 5:35
                                               Re: Brakes/Struts into 1200 Ute lowendtheory 2007/9/28 8:21
                                                 Re: Brakes/Struts into 1200 Ute Trav 2007/9/28 8:24
                                                   Re: Brakes/Struts into 1200 Ute lowendtheory 2007/9/28 8:54
                                                     Re: Brakes/Struts into 1200 Ute PIGDOG 2007/9/28 10:29
                                                       Re: Brakes/Struts into 1200 Ute lowendtheory 2007/10/2 11:42
