#1 ca18det dies when turbo spools up
perthute Posted on: 2008/2/16 10:54
is it a vac line or something ??
any help would be great .
IM DIEING TO DRIVE IT AND ITS ALL READY TO GO BUT NO BOOST
#2 Re: ca18det dies when turbo spools up
old_school Posted on: 2008/2/16 11:50
More information required?
What do you mean buy it dies when turbo spools up?
Does it start and idle?
Can you drive it at pre boost rpm?
Does it cough, stall etc when the turbo starts producing boost?
Do you have a boost gauge? To tell if it is producing boost?
Is the Vac line from the compressor wheel connected to the wastegate and boost control box thing (Sorry cant think of its name)
#3 Re: ca18det dies when turbo spools up
perthute Posted on: 2008/2/16 16:02
What do you mean buy it dies when turbo spools up? has soon as turbo spools up ( hits boost ) or ( i think 2500rpm ) it just dies in the ass
Does it start and idle? yep starts up idles
Can you drive it at pre boost rpm? yep can drive all the way up too 5 gear
Does it cough, stall etc when the turbo starts producing boost? yea kind of
Do you have a boost gauge? To tell if it is producing boost? no sorry no boost gauge
Is the Vac line from the compressor wheel connected to the wastegate and boost control box thing (Sorry cant think of its name)had a mate whos realy good with siliva's round and 3 hours later nothing . hes my go too man so im realy ####ed now i think its gonna have to go to a performance shop wat a pitty
im dieing to feel the boost
#4 Re: ca18det dies when turbo spools up
hotrocket Posted on: 2008/2/16 21:36
thinking....hows the impella sharft (tight)
Silly question but maybe fuel filter blocked?
How about the computer, standard or been changed to the motor requirments?
#5 Re: ca18det dies when turbo spools up
frankthedolphintrainer Posted on: 2008/2/16 23:47
it might be the tuning of the ecu too much air to fuel or vice versa. it also could be your fuel system not working eg fuel pump, injectors ....
#6 Re: ca18det dies when turbo spools up
Ronald Posted on: 2008/2/17 1:30
the actuator...
It will more than likely be the fuel system. start with new fuel filter (if you are using a directional one don't play funny buggers and put it in backwards)
run some injector cleaner etc in the tank.
maybe hotwire the fuel pump and ignition (use the existing power wires as a signal to turn on a relay that has power directly from the battery)
ummm... reset ECU (disconnect battery -ve over night overnight)
perhaps it might be worth seeing if it smokes when it "dies". if it smokes it may be a lack of compression (rings are shot) if it doesnt then it suggests there is not enough air or fuel.
maybe take it for a run without an air filter.
#7 Re: ca18det dies when turbo spools up
woody Posted on: 2008/2/17 1:52
is the actuator or the wastegate sticking/stuck open, we had a problem similar to this at work on a xr6 turbo ute
and that was the problem
#8 Re: ca18det dies when turbo spools up
carjunkie Posted on: 2008/2/17 4:11
Try checking your cat converter. If its blocked up a bit it will let the motor work to a point, then when you start boosting there is nowhere for the gas to go effectively choking the motor.
#9 Re: ca18det dies when turbo spools up
perthute Posted on: 2008/2/21 7:33
ok well it doesnt have a cat converter and new fule filter new fule lines , the motor is all standard inc the ecu
anyways it just got dropped off at the shop so any bets my bets on fule pump but realy i dont have a f###ing idea
o one more clue in first gear if i give it full throttle it gets some big bangs out the exorst
#10 Re: ca18det dies when turbo spools up
appsy1 Posted on: 2008/2/21 8:08
could be a timing issue??
