Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Brake problem
rx1200wagon
Posted on: 2008/3/6 5:46
i have a 1200 wagon with disc brakes on the front, recently the more i used the brakes they would start to stay on to the point where the were completly locked on, i tried a new brake master which didnt solve the problem, i then tried changing the piston seals and the brake pads but still hav the problem, does anyone hav any idea wat the problem could be? its only happening on the front not the back
#2
Re: Brake problem
1200rallycar
Posted on: 2008/3/6 6:16
sounds like a piston is jamming in the caliper
does it pull to one side when you brake? or when you let the brakes off but it is still rubbing?
#3
Re: Brake problem
L18_B110
Posted on: 2008/3/6 6:39
residual pressure valve inthe master cylinder...
#4
Re: Brake problem
Cable_Tie
Posted on: 2008/3/6 7:18
Have you recently changed from drums up front?
#5
Re: Brake problem
cheater_5
Posted on: 2008/3/6 8:13
all 1200wagons came with drums up front from factory. i put kb110 struts and brakes into my wagon without removing residual valve and had no problems what so ever so the whole time i was driving on them. nada, zip zero and they went well.
#6
Re: Brake problem
dattodude
Posted on: 2008/3/6 8:23
I'd look for a 120Y master cylinder, using a car's MS that had a disc/drum combination from the factory.
Does sound like a residual pressure valve issue, but it's also likely you have crap in the master cylinder. If you could be bothered, Pull out the master cylinder and give it a cleanout. including clearing the air galleries from the MC bore to the brakeline fittings with a paperclip. put brake fluid on everything and reassemble.
#8
Re: Brake problem
dat141
Posted on: 2008/3/6 9:52
Make sure you have some clearance between the brake pushrod and the master cylinder piston when the brakes are off. If not the compensating port could be blocked due to the piston not fully retracting and as the fluid heats up and expands, it locks the brakes on. I've had this happen before on a P.D inspection due to bad master cylinder to booster clearance and it resulted in very smoky brakes.
#9
Re: Brake problem
rx1200wagon
Posted on: 2008/3/7 7:31
thanx for the feedback, tomorrow ill try adjusting the push rod clearance, if that dosnt work the try replacing the rubber hoses but im not sure if that is the problem coz its happening to both the front brakes at the same time, ive replaced the master cylinder with a new one so its not the residual pressure valve
#10
Re: Brake problem
wardat
Posted on: 2008/3/7 11:10
one thing to try before u get too invovled with removing and testing other things, lubricate the brake pedal pivot point where the pin goes through. we recently had the exact same problem on our race car and we ended up replaceing the mastercylinder and rechecking the pushrod adjustment a few times and it all turned out to be a seazing pivot point.
