can a Z18ET/CA18ET twin spark dizzy&ecu be put on a L16T
From Adelaide, Australia
hey guys motor reg in s.a will let me have a L16 in a 1200. i want to turbo the L16 using a stock nissan ECU (easy and cheap to wireup). the only nissan SOHC turbo engines that i know of are the Z18ET and the CA18SOHC turbo but they use a 8 plugged dizzy. if i were to fit the dizzy and ecu stuff on the L16T could i get away with only using 4 of the 8 dizzycap outputs? or would it be bad to run E15et ecu on a turbo L16, would it lean it out to much because its 100 cc bigger.i know alot of u say why but i have my reasons.
Posted on: 2008/5/25 9:52
Subject Poster Date
     can a Z18ET/CA18ET twin spark dizzy&ecu be put on a L16T Matto1kUte 2008/5/25 9:52
       Re: can a Z18ET/CA18ET twin spark dizzy&ecu be put on a L16T dazza1200 2008/5/25 10:28
       Re: can a Z18ET/CA18ET twin spark dizzy&ecu be put on a L16T Godzilladat 2008/5/28 7:42
