#1 FS: 240K calipers and discs - bolt onto stanza/200b
Daveman Posted on: 2008/9/16 12:07
I've just upgraded my brakes so am selling the old setup.
They are the 256? mm rotors that work with the Stanza/200b strut. I bought the rotors new about 4 years ago but realistically they've only done a few thousand k's.
calipers are in good condition with a set of 95% bendix advance pads.
$200
#2 Re: FS: 240K calipers and discs - bolt onto stanza/200b
PIGDOG Posted on: 2008/9/16 12:12
253mm rotor
same brake setup as what was first on my car....back in the day
good upgrade over the el crappo stock stanza brakes
#3 Re: FS: 240K calipers and discs - bolt onto stanza/200b
Mildman Posted on: 2008/9/16 14:38
This is the setup I still have on my coupe, rotors look in pretty good nick too!
#4 Re: FS: 240K calipers and discs - bolt onto stanza/200b
revhead001 Posted on: 2008/9/16 14:41
PIGDOG wrote:
....back in the day
And how old are you? 20? Back in your box young whippersnapper. Your still in bloody school for christ sake... back in the day! Sheesh.
#5 Re: FS: 240K calipers and discs - bolt onto stanza/200b
PIGDOG Posted on: 2008/9/16 15:01
hahaha if it was a couple of days ago you would have been wrong about my age
it was a long time ago in the timeline of stuff thats been done to my car....not so long ago in reality though
#6 Re: FS: 240K calipers and discs - bolt onto stanza/200b
TOSSER Posted on: 2008/9/16 22:55
If my 1200 coupe is still running standard struts and booster, what else do I need to fit this gear?
#7 Re: FS: 240K calipers and discs - bolt onto stanza/200b
Daveman Posted on: 2008/9/17 2:46
You're gonna need either stanza or 200b struts unfortunately.
#8 Re: FS: 240K calipers and discs - bolt onto stanza/200b
TOSSER Posted on: 2008/9/17 2:57
To fit stanza struts, I will need stanza control arms, tie rod, tie rod ends....won't I?
#9 Re: FS: 240K calipers and discs - bolt onto stanza/200b
Daveman Posted on: 2008/9/17 3:11
taken from
stanza struts tech write up
The bits I used:
* early 80's stanza struts with alloy girlock calipers & 245mm solid rotors. (Pre 7/1979 stanzas had the dodgy calipers so steer clear of these)
* Lovell super low stanza springs
* monroe gas shocks (came with the struts but presumably std. stanza ones)
* stanza brake hoses
* Stanza Lower Control Arm's (LCA's)
* 120Y radius rods (tension rods) & sway bar
#10 Re: FS: 240K calipers and discs - bolt onto stanza/200b
TOSSER Posted on: 2008/9/17 4:20
Thanks Dave. Are you still using the stanza stuts for your next upgrade? What are you putting on them?
