(1) 2 3 4 »
#1 1200 X-member
hotrocket Posted on: 2008/11/15 20:08
Hey guys have any of you got a ajustable X-member........mine is!!
Ive seen quiet a few member around that are non ajustable?
or is theres a differents between B120 X-member models....??,
while on the subject hoo has a member made for there ca18, may i see it!!!
id like some idea's
thanks fella's
#2 Re: 1200 X-member
pepper Posted on: 2008/11/15 21:47
in what way is it adjustable?
#3 Re: 1200 X-member
hotrocket Posted on: 2008/11/15 21:49
where the control arms link up...
#4 Re: 1200 X-member
Tyrie Posted on: 2008/11/16 2:27
You mean you have more holes drilled to increase track and camber? I thought that was pretty common?
#5 Re: 1200 X-member
hotrocket Posted on: 2008/11/16 5:03
its elongated,......do you have one?
most of the members ive seen arnt
pretty common im not sure!!
#6 Re: 1200 X-member
hotrocket Posted on: 2008/11/16 7:42
while on the subject about X-member any you guys custom made your own to carry ca18det,
may i see it!!!
id like some idea's please!
#7 Re: 1200 X-member
1200rallycar Posted on: 2008/11/16 7:50
have seen photos of one on here which had a cam setup for minor adjustment...
if its not a cam setup i think it sounds quite dodgey
#8 Re: 1200 X-member
hotrocket Posted on: 2008/11/16 8:02
looking at the weld job,......its looks very factory
if i can post up a pic you can see what i mean
#9 Re: 1200 X-member
ZigZag Posted on: 2008/11/16 9:35
if its a late model say 1980 or so X-member then it will have bolt holes drilled... earlier ones dont.... this helps with using stanza ball joints when ur upgrading to R31 front struts.... Baz from Datsport.com told me this
#10 Re: 1200 X-member
hotrocket Posted on: 2008/11/16 10:10
Tryed put it up.......not happening, so it in ........ "PHOTO ALBUM"
(1) 2 3 4 »
