Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#51
Re: SR20DET Sunny
SRB310
Posted on: 2009/2/16 11:45
Yep- was one more email before I cut it in, even briefer description.. I'm in the wrong trade! Thought I would leave that in, someone might get a laugh.DatsAndy- No other mods or massaging. I was hoping for a hole approx 80x80 but just kept cutting until I could get the cross member to bolt in.
#52
Re: SR20DET Sunny
datsunsunny
Posted on: 2009/2/19 12:20
correct me if i am wrong srb310
but as long as i can see u cut the member traveling from side to side of the car and that as long as i know plays an important part in the strenght of the car. how r u going to get that strenght back. i mean any modifications planed?
#53
Re: SR20DET Sunny
SRB310
Posted on: 2009/2/24 11:08
Yes, I have cut straight through the seat support. As per the engineers instructions i will be putting strength behind to rejoin the support, and then around the cut-out and basically boxing that section in. After that a thin cover sheet over the top.
The email from the engineer is a little hard to decipher, but will be checking with him before final welds are made. That support is mainly for the seats, but will probably be stronger than original when complete.
#54
Re: SR20DET Sunny
datsunsunny
Posted on: 2009/2/24 15:38
that is all i ment with my question dude. i am basically doing the same thing as u r but i am lagged a little bit behind. the only difference between the two of us is that i am using an sr20det gtir engine.
have u thought anything about upgrading the brakes?
#55
Re: SR20DET Sunny
SRB310
Posted on: 2009/2/26 14:11
Maddat over here do a RX7 series 4/5 kit that will bolt in but i'll probably go for r32 4 spots or similar, have to keep it Nissan
As for the rears, a shortened Skyline rear may go in, so just the standard R31 discs from there will stay.. Still have a lot of work to do !!! Keep us updated on your build as well, always helps to see how other people are doing things.
#56
Re: SR20DET Sunny
datsunsunny
Posted on: 2009/2/26 20:28
same here r32 skyline and z32 master cylinder which also includes the front-rear compensator in the same unit and is bolt on in the booster.
i m going for the s14 suspention system and hilux diff the only thing that is not nissan since r31 skyline have never been sold here i ll post my photos in the following days but the car is still in early stages.
#57
Re: SR20DET Sunny
SRB310
Posted on: 2009/3/1 8:52
I'm still debating the Hilux diff- Long time till I have to decide so we'll see what I can get my hands on between now and then..
Z32 master cylinder hey.. will have to look into that, cheers!
#58
Re: SR20DET Sunny
PIGDOG
Posted on: 2009/3/1 9:18
z32 master is a bad idea, they are biased for a front heavy car and will be way out for yours. try an s13 one as they will be much better suited and are externally the same as z32
#59
Re: SR20DET Sunny
SRB310
Posted on: 2009/3/1 9:54
Thanks for the input PIGDOG, that's why I'm here- need all the help I can get!
#60
Re: SR20DET Sunny
datsunsunny
Posted on: 2009/3/2 12:46
10x piggy dog for the add but does the s13 include the front-rear compensator in the same unit as the z32
