WTB 1200 wagon or ute diff mounts
Not too shy to talk
Hi guys
I was just after some 1200 wagon or ute diff mounts. the bottom plate were the shock mounts to. thanks heaps...
Posted on: 2009/7/9 3:49
Re: WTB 1200 wagon or ute diff mounts
The shock mounts for ute, coupe and wagon are on the leaf spring plates. They look similar but have three different part numbers. Can they be used interchangeably? The later ute one is shaped differently
Maybe 1971-1973 ute (H145 diff) will interchange with wagon.
Posted on: 2009/7/9 3:58
Not too shy to talk
any one will do because the top holes are getting drilled out to fit the bigger r31 diff.and the shock mount should be correct so im told.
Posted on: 2009/7/9 4:43
