Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
leaf springs
iDatto
Posted on: 2009/7/18 7:13
i just grinded the head off the bolt that holds the springs together. was this a bad idea?
there is still a bolt in there but is got a slither of a head cus i grinded that part off
#2
Re: leaf springs
silvia-specr
Posted on: 2009/7/18 7:18
The head on a standard bolt will not be round like a centerbolt will be, normally a slight bit shorter too. Just use one out of another spring pack, if you have available, most centerbolts are only grade 2 material.
#4
Re: leaf springs
silvia-specr
Posted on: 2009/7/18 7:38
Did you grind the nut off or the cylinder shaped side of the bolt?
#6
Re: leaf springs
iDatto
Posted on: 2009/7/18 7:43
oh oh i get it, um i cut it off so i could get the lowering blocks to line up, so i dont really want to put another one in, i need it to be out really
#7
Re: leaf springs
silvia-specr
Posted on: 2009/7/18 7:46
is it bolt that is in the center of the spring pack or a rivet that is holding clip on towards the ends of the spring?
#8
Re: leaf springs
silvia-specr
Posted on: 2009/7/18 7:51
You need a centerbolt, other wise it won't stay centered to the axle, your block should have a nub on one side and a dimple on the other for proper installation. centerbolt should fit inside the dimple side of the block.
#9
Re: leaf springs
iDatto
Posted on: 2009/7/18 9:37
yeah the dimple is to far forward. could i drill holes either side of the blocks and put bolts there, so it wont go forward, and wont go backwards??
#10
Re: leaf springs
aidaniel
Posted on: 2009/7/18 10:13
the hole in the blocks should line up with the pin ... this lines up the diff under the car
