Re: 1200gx head on a14
If it is a true Datsun 1200 GX head (1970-1973), it will have the oil passage drilled in the head face that all original A-series heads have. If it is a 1973-1975 A12T head it will be identical but without the oil passage.
In other words, no different than swapping any early head to late block.
You will need an intake manifold for the GX head or A12T head, as the ports (30 mm x 36 mm) are much bigger than A14 ports (28 mm x 34 mm).
Posted on: 2009/7/21 20:53
Subject Poster Date
     1200gx head on a14 nismo1 2009/7/21 20:35
       Re: 1200gx head on a14 ddgonzal 2009/7/21 20:53
