Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#21
Re: A14 crank into a12
A14force
Posted on: 2009/11/2 7:45
Part of me would like to build one of these motors too. I have an A14 crank, and a lathe capable of turning it down to clear the piston skirt. I also know where there is an A12A out of an LHD 310 2dr sedan. it's a shortblock, and I reckon the guy would probably sell it for next to nothing.
I did read an article about long vs shortrod motors somewhere. While long rods are prefered, it did say that a short rod wasn't always a minus on a turbo or nitrous engine. If you're using an A12 block for originalities sake, or for class regs then I guess those two options are pretty irrelevent. You spoke of using a 77mm bore D/man. I had thought that 76 was the limit of an A12 block?
#22
Fandatstick
Posted on: 2009/11/2 10:28
Factory offered 76.8mm competition pistons for 1298cc capacity. 78mm bore isn't unheard of (but probably getting risky maximum) for 1340cc.
#23
Dodgeman
Posted on: 2009/11/9 13:00
My own 1200 engine that I used in my B10 sedan was bored to 76mm untill I eventually wore it out, so I bored it again to 76.5mm, ... again using A14 pistons. The only thing that finally brought this engine to a stop was a completely burned out exhaust valve but the bores are fine. A local bloke here with a 1200 coupe is running a 77mm bore in a 1200 block & it runs sweet [& fast] This engine uses an A14 crank & regularly sees 6,000 + rpm, although I suspect that this bore size would be pretty much the limit.
#24
rally1200
Posted on: 2009/11/9 14:05
In my Early A12 rally engine( Front Dizzy ) I ran 78mm Mazda pistons for 2 years with no problem, the engine finally died when a radiator hose failed and the engine melted.
#25
D
Posted on: 2009/11/9 23:27
what have you guys done for head gaskets in these big bore beauties?
#26
Dodgeman
Posted on: 2009/11/10 12:45
In my case I used a DatsunSport big bore gasket for the 1200 engine when it was 76mm, but I switched to an A14 gasket, suitably modified with a wad punch for the rocker oiling hole, when I rebored it to 76.5mm.
I don't know what was used in the stroker engine that I wrote of in my last post. This engine used an A15 head so some thought & work would have been required.
#27
Unv-Ute
Posted on: 2010/10/12 22:47
hey umm just a bit of a noob question how much do i need to skim of the crank to get it to spin freely
#28
Slowbuild
Posted on: 2014/6/9 20:08
Thanks for the info, I would also like more information on resizing the crank if anyone has it.
#29
Posted on: 2014/6/9 21:41
About 10 mm - more than a skim. And of course the crank needs to be rebalanced after the machining process.
See http://datsun1200.com/modules/mediawi ... Crankshaft_into_A12_Block You can view topic.
