F/S S13 Discs And Calipers
From Armidale N.S.W
As Above S13 Discs And Calipers Discs will need a real good machining and new pads etc in Calipers. PM me for Mobile and make An offer not sure on the going rate. Will post at your expense. Cheers Andrew
Posted on: 2010/2/25 1:01
73 1200 wagon SOLD
Re: F/S S13 Discs And Calipers
ca18 det/de or sr20det/de ?
they change in size might help your sale :)
Posted on: 2010/2/25 2:30
1200 ute unfinish'd sr20 $$$
1200 ute stocko
bumble bee drift pig
XR8 tow car / daily
bailz is orsum
From Armidale N.S.W
Not sure what model but from memory there 280mm same as the ones im running on me wagon.
Posted on: 2010/2/25 3:11
73 1200 wagon SOLD
280mm are the bigs ones :)
Posted on: 2010/2/25 5:34
1200 ute stocko
XR8 tow car / daily
bailz is orsum
Not too shy to talk
Am i after the big size for conversion on a 78 120y ?? If so consider them sold. Guessing i need the smaller size though.
Posted on: 2010/3/1 15:33
From Armidale N.S.W
We are running the 280mm ones with 14 inch rims couldnt run much smaller unless you used spacers and depending on wheel offset.
Posted on: 2010/3/2 0:16
73 1200 wagon SOLD
