Re: A series clutchs ,all the same ?
They are different.
The clutch disc size is the same: 180mm with 18T spline. But the material varies.
The clutch cover (pressure plate) vastly different from A12 to A14. Yes they will bolt up, but a true original A12 plate will slip behind an A14.
My advice is to use the 60-series transmission (56-series is rated for less torque than A14 puts out). Use the A14 pressure plate & disc. Use the A12 or A14 flywheel, your choice. The A12 flywheel is lighter so slightly better acceleration. The A14 flywheel will provide notably smoother driving.
Posted on: 2010/6/30 14:07
Subject Poster Date
     A series clutchs ,all the same ? estyre 2010/6/30 10:24
       Re: A series clutchs ,all the same ? levey 2010/6/30 11:01
         Re: A series clutchs ,all the same ? armiee 2010/6/30 11:05
           Re: A series clutchs ,all the same ? benny 2010/6/30 11:07
       Re: A series clutchs ,all the same ? levey 2010/6/30 11:08
       Re: A series clutchs ,all the same ? DATUTE1 2010/6/30 11:53
         Re: A series clutchs ,all the same ? levey 2010/6/30 11:56
           Re: A series clutchs ,all the same ? levey 2010/6/30 11:58
       Re: A series clutchs ,all the same ? DATUTE1 2010/6/30 12:32
       Re: A series clutchs ,all the same ? levey 2010/6/30 13:59
       Re: A series clutchs ,all the same ? ddgonzal 2010/6/30 14:07
       Re: A series clutchs ,all the same ? DATUTE1 2010/7/1 11:23
       Re: A series clutchs ,all the same ? estyre 2010/7/2 0:40
         Re: A series clutchs ,all the same ? estyre 2010/7/2 0:41
           Re: A series clutchs ,all the same ? PIGDOG 2010/7/2 1:06
           Re: A series clutchs ,all the same ? ddgonzal 2010/7/2 1:23
             Re: A series clutchs ,all the same ? ddgonzal 2010/7/2 3:49
               Re: A series clutchs ,all the same ? estyre 2010/7/2 5:17
                 Re: A series clutchs ,all the same ? ddgonzal 2010/7/2 5:49
                 Re: A series clutchs ,all the same ? benny 2010/7/2 6:32
                   Re: A series clutchs ,all the same ? ddgonzal 2010/7/2 6:47
         Re: A series clutchs ,all the same ? benny 2010/7/2 1:22
       Re: A series clutchs ,all the same ? levey 2010/7/2 13:12
         Re: A series clutchs ,all the same ? dattoman_1000 2010/7/2 15:20
           Re: A series clutchs ,all the same ? ddgonzal 2010/7/2 18:55
             Re: A series clutchs ,all the same ? estyre 2010/7/3 1:16
               Re: A series clutchs ,all the same ? datski620 2010/7/3 1:32
