Re: Rotary crossmember
From Perth
Well I had a look at the 2 rotary 1000's and the mount setup won't help you. They both use a solid engine plate across the front of the engine locating on the 2 chassis rails in line with the rearward bumber mount bolt.
So no good for street
Posted on: 2003/12/7 12:10
Subject Poster Date
     Rotary crossmember D 2003/12/7 8:26
       Re: Rotary crossmember dattodude 2003/12/7 9:03
         Re: Rotary crossmember dattoman_1000 2003/12/7 12:10
       Re: Rotary crossmember stirlingmac 2003/12/7 13:24
         Re: Rotary crossmember D 2003/12/8 0:49
           Re: Rotary crossmember Wattage 2003/12/8 7:36
             Re: Rotary crossmember MadTimo 2003/12/8 13:19
               Re: Rotary crossmember MadTimo 2003/12/8 14:08
                 Re: Rotary crossmember Wattage 2003/12/8 21:54
                   Re: Rotary crossmember datsterr 2003/12/9 0:19
                     Re: Rotary crossmember D 2003/12/9 11:53
