Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Weber carb
dat16
Posted on: 2004/1/16 3:48
I've been offered a sidedraft 45 weber on an L series manifold with a custom made cold air box to use on my 1600 autocrosser.
I'm wondering if this carby could be run on my stocko 1200 without much drama. Obviously i will need an a series manifold but will the carby be overkill for a 1200????? (this setup will only cost me $200.00 dollars)
#2
Re: Weber carb
1200rallycar
Posted on: 2004/1/16 4:19
my guess is jets and chokes will need to be changed, and thats gonna cost bout $130 in parts, but if you get it setup well itll be pretty damn good
#3
Re: Weber carb
dat16
Posted on: 2004/1/16 5:04
So in theory once choked and jetted it should run ok????
Would it be worth the effort on a standard 1200 (I'm happy with any increase in performance) or should i just stick it on the 1600 and forget about it.???
#4
Re: Weber carb
1200rallycar
Posted on: 2004/1/16 5:24
seein its setup for the 1600, id say use it for that as including manifold and everything else the price to fit to the a-series wont be worth it, put ti on the autocrosser and get a 32/36 downdraught for the 1200
#5
Re: Weber carb
Razor
Posted on: 2004/1/16 6:13
Im looking at buying this 32/36 weber but it was in 1979 Stanza with L20B engine and the carby is electric choke my question is this a straight bolt-on to my '81 Sunny A12? cos I thought I need a manual DGV series for my A12
Please advise the carby is only $200 with linkages and k & N filter
#6
Re: Weber carb
Posted on: 2004/1/16 8:10
The L20B uses a different adapter plate for the carb.
Electric choke? That's what most 1200s have, at least in the US. My 32/36 was a DGAV, I just took the water-heated choke off and fit an electric choke, instantly turning it into a DGEV. The electric choke wire is powered by the IGN wire (before the ballast resistor -- full 12V). It is normally switched through a relay hooked to the alternator 'N' output, but that isn't strictly necessary. The relay is not to handle the current, it's just that the N output enables the relay only if the engine is actually running.
#7
Re: Weber carb
Razor
Posted on: 2004/1/16 13:41
I'm sorry i'm a bit newbie
just learning... are 1200 here in australia have electric choke? how about B310 sunny? You can view topic.
