Modin a 1200 engine
What little mods can I do to make a 1200 a bit faster....In terms of exhaust,carburetor,extractor.
And would it be best to use 2-1/2''or 3'' piping for the standard 1200 engine?
Posted on: 2004/1/23 4:34
Re: Modin a 1200 engine
The best exhaust pipe for a stock A12 engine is 1.5 inch. If you have a bigger carb, use 1.75 inch.
You would probably need 200hp for a 2-1/2 inch pipe ...
Posted on: 2004/1/23 5:43
From Perth, Australia
Is a 2" overkill with stock manifold ?
Posted on: 2004/1/23 6:10
1974 120Y Coupe
40 thou overbored A14
32/36 DGV Weber
5 Speed Gearbox
New Interior (in the making)
My website
From Perth W.A
thats what i have and it's fine, i did it so it was ready for extractors. i say an 2" system with extractors and a 32/36 webber would be a good start. and a proper tune when you have your webber fitted
Posted on: 2004/1/23 6:22
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
2" is probably optimum if you have headers and larger carb ... and do most of your driving at high rpms. A big exhaust pipe won't necessarily make your engine run poorly, you just won't get optimum acceleration.
General rule of thumb, the larger the engine, the bigger the pipe. For example:
- 150hp 3-liter engine: 2-1/4 inch single exhaust
- 150hp 4-liter engine: 2-1/2 inch single exhaust
But these are just generalizations. It depends on various things.
Check out this information: MagnaFlow's Frequently Asked Questions
Posted on: 2004/1/23 6:38
