Re: 240K Max negative wheel offset
15" tires on 8" wheel?
BFGoodrich Radial T/A
225/60SR15
235/60SR15
Rim Width Range: 6-9"
http://www.tirerack.com - search by size, pick BFGoodrich, which has one of the largest range of sizes, then click Specs.
Posted on: 2004/2/12 5:49
Subject Poster Date
     240K Max negative wheel offset Razor 2004/2/7 23:04
       Re: 240K Max negative wheel offset Dodgeman 2004/2/7 23:39
         Re: 240K Max negative wheel offset Razor 2004/2/8 23:37
           Re: 240K Max negative wheel offset ddgonzal 2004/2/8 23:46
             Re: 240K Max negative wheel offset Razor 2004/2/9 0:19
               Re: 240K Max negative wheel offset ddgonzal 2004/2/9 1:34
                 Re: 240K Max negative wheel offset Razor 2004/2/12 5:19
                   Re: 240K Max negative wheel offset ddgonzal 2004/2/12 5:49
                   Re: 240K Max negative wheel offset L18_B110 2004/2/13 1:34
                     Re: 240K Max negative wheel offset Razor 2004/2/13 4:02
                     Re: 240K Max negative wheel offset Dodgeman 2004/2/13 15:59
