Re: B110 Tacho questions
The Datsun factory wiring is before the resistor. But you may be able to do it otherwise.
He's about putting a Coupe dash (early round gauge cluster) in a sedan that has wiring for a rectangular gauge cluster.
Apparently you can wire the tachometer multiple ways and it will work OK.
If you use the factory wiring, or splice into the POS side if the IGN circuit, you don't have to run wires from the engine compartment into the passenger compartment.
But do whatever seems easier, reports are good.
Posted on: 2011/6/26 2:14
Subject Poster Date
     B110 Tacho questions racer135 2011/6/22 10:21
       Re: B110 Tacho questions lamb_daiquiri 2011/6/22 11:43
         Re: B110 Tacho questions benny 2011/6/22 12:06
           Re: B110 Tacho questions racer135 2011/6/22 13:09
       Re: B110 Tacho questions edp 2011/6/22 16:17
         Re: B110 Tacho questions ddgonzal 2011/6/23 0:10
       Re: B110 Tacho questions lamb_daiquiri 2011/6/23 9:15
         Re: B110 Tacho questions racer135 2011/6/23 9:57
       Re: B110 Tacho questions lamb_daiquiri 2011/6/23 10:00
         Re: B110 Tacho questions racer135 2011/6/23 10:37
           Re: B110 Tacho questions lamb_daiquiri 2011/6/23 11:10
           Re: B110 Tacho questions ddgonzal 2011/6/23 17:13
             Re: B110 Tacho questions racer135 2011/6/24 14:18
               Re: B110 Tacho questions ddgonzal 2011/6/24 15:32
                 Re: B110 Tacho questions racer135 2011/6/25 13:02
       Re: B110 Tacho questions racer135 2011/6/23 11:15
         Re: B110 Tacho questions racer135 2011/6/23 11:35
       Re: B110 Tacho questions lamb_daiquiri 2011/6/23 11:20
       Re: B110 Tacho questions ddgonzal 2011/6/26 2:14
       Re: B110 Tacho questions lamb_daiquiri 2011/6/26 4:37
