Lca- which to use for bit more track
Well I have unknown lcas with my car, but they are either stanza or sunny for the stanza/200 b combos I have used.
Are there any other lcas I can use from factory that use the stanza ball joints?
Only things in front end that haven't been replaced are draglink, idler arm and lca bushes over the years. I'm about to do all 3 hoping to permanently eliminate a stupid wobble I have always had (not as bad since upgrading tie rods and ball joints) than it used to be.
Car pulls left slightly too so thought if I could source lcas all in the one hit
Posted on: 2012/4/2 4:33
Re: Lca- which to use for bit more track
Maddat! :) late ute and stanza ball joints are differant to mik! Stanza all the way! If u want more go adjustable ones
Product No - LCA1200
Posted on: 2012/4/2 4:58
Edited by supafatto on 2012/4/2 5:18:38
Car free
No they bolt up to lca the same it's just their angle and neg camber that differs
Posted on: 2012/4/2 5:31
They do bolt up the same but measure from center of ball joint to blots is different! Plus kpi is a slight grater
Posted on: 2012/4/2 5:54
Car free
Redrill xmember! One setup for track one for street 20mm offset :)
Posted on: 2012/4/2 5:55
Car free
From Perth WA AUS
If you increase the offset by 20mm won't you need adjustable caster rods? Or is there enough adjustment in the originals?
Cheers.
Posted on: 2012/4/2 11:59
Datsun 1200 2Dr sedan.
He has adjustable castors
Posted on: 2012/4/2 12:11
Car free
From Melbourne, Australia
why do you want more track? tyres will start hitting wheel wells and front of guards too?
you have adjustable tops yeah? get 1 degree ned and as much castor as possible?
had a re-drilled x-member about 8 years ago, was drilled 10mm out and used 120y castors no prob
Posted on: 2012/4/2 12:18
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Perth WA AUS
Mik where did you get your adj casters from and how much? (did they cost).
Posted on: 2012/4/2 12:24
Ummmm didnt cost anything... Just more thread on
Stock ones
Posted on: 2012/4/2 12:51
