Re: I Need Help!
Good on ya. If the new switch doesn't fix it, don't give up. It could still be a wiring problem. That's why testing the switch first is a good idea.
how do you jump the coil?
Place a jumper -- a length of wire -- from BAT + to the coil +. Loosen the coil + terminal and stick the wire in it and re-tighten. Often you can jam the other end of the wire in the battery terminal. This is a hot-wire, so be careful. Don't drive it like this, but it's OK for testing (it doesn't have fuse protection and if it gets loose may short out, and the key won't turn the ignition off since it is hot-wired).
Posted on: 2012/5/4 0:06
Subject Poster Date
     I Need Help! AgentWright007 2012/5/3 19:38
       Re: I Need Help! ddgonzal 2012/5/3 19:49
         Re: I Need Help! AgentWright007 2012/5/3 20:08
         Re: I Need Help! AgentWright007 2012/5/3 20:55
           Re: I Need Help! ddgonzal 2012/5/3 22:18
             Re: I Need Help! AgentWright007 2012/5/3 22:36
               Re: I Need Help! ddgonzal 2012/5/3 23:00
                 Re: I Need Help! AgentWright007 2012/5/3 23:23
                 Re: I Need Help! ddgonzal 2012/5/3 23:36
                   Re: I Need Help! ddgonzal 2012/5/3 23:43
                     Re: I Need Help! AgentWright007 2012/5/3 23:47
                     Re: I Need Help! ddgonzal 2012/5/3 23:56
                       Re: I Need Help! AgentWright007 2012/5/4 0:00
                         Re: I Need Help! ddgonzal 2012/5/4 0:06
       Re: I Need Help! jmac 2012/5/4 13:42
         Re: I Need Help! ddgonzal 2012/5/4 18:11
       Re: I Need Help! jmac 2012/5/5 5:53
       Re: I Need Help! bakat 2012/5/5 7:34
         Re: I Need Help! AgentWright007 2012/5/5 14:58
           Re: I Need Help! ddgonzal 2012/5/5 20:08
       Re: I Need Help! Rallytwit 2012/5/5 21:36
