#1 Jetting.
darrenwilson Posted on: 2012/7/8 4:20
Using stock hitachi a12 Cabby. Could it be Jetted/Upgraded to be used on a stock A15 engine.Other carburettors here ar very expensive.
Cheers.
#2 Re: Jetting.
ddgonzal Posted on: 2012/7/8 5:00
Yes it can be jetted down.
Or you can use it as-is.
#3 Re: Jetting.
darrenwilson Posted on: 2012/7/9 4:48
So What do u recomend that i do?
#4 Re: Jetting.
ddgonzal Posted on: 2012/7/9 5:00
Put it on. Run it. Then depending on how it runs, re-jet appropriately. It may need smaller jets for the A15.
A12 carburetor is smaller than A15 carburetor. But it will run good, just won't have the same peak HP as it does not flow as much air. Under 4,500 RPM you probably won't notice any difference.
#5 Re: Jetting.
darrenwilson Posted on: 2012/7/9 5:09
Thanks..Woundering if I could swap jets from other carbs.What sizes do I need.
Want to swap jets to Increse Fuel.
#6 Re: Jetting.
ddgonzal Posted on: 2012/7/9 5:12
Don't do that. Jetting is first and foremost related to the venturi sizes, and the A12 and A15 venturi sizes are different.
To properly jet a carburetor, put it on the engine and look at the results. If it is running rich, go two jet sizes smaller. If it runs leans, go two jet size larger. Then re-test. There are no easy answers.
