#1 stanza rear shocks.
Posted on: 2012/10/25 7:49
Are stanza rear shock bushes same as 1200 sedan ones? All my bushes are about 30mm wide and same of with a 10mm bolt through centre.
Stanza are 35wide and 15 mm bolt similar od.
Part numbers are same for most Nissan rear bottom bush for cars of that era. Including b110 210 310 620 etc. but can't see stanza or a10
Compressed height at 39cm same but.longer uncompressed height at 59 to 63cm
#2 Re: stanza rear shocks.
Posted on: 2012/11/1 4:40
Bump. Any one know if can use stanza rear shocks with a bw68 diff from 120y?
#3 Re: stanza rear shocks.
ddgonzal Posted on: 2012/11/1 6:03
B110 shock upper bushes
56112-09400 BUSH (2) 2 SEDAN
* superseded by 56112-W5000
A10 Stanza (Japan version)
56112-W5000 lo-power versions
56112-09400 hi-power versions
The bushings with larger I.D. i would not use. They could allow the shock piston to touch edge of the hole in the body - resulting in vibration.
#4 Re: stanza rear shocks.
Posted on: 2012/11/1 6:12
What about bottom bushes that connect the shock to the rear leaf as springs?
#5 Re: stanza rear shocks.
ddgonzal Posted on: 2012/11/1 6:52
The bottom bush on Sedan shocks is press-fitted during manufacturer and so is not sold seperately.
All other 1200s have removable bottom bushings.
#6 Re: stanza rear shocks.
Posted on: 2012/11/1 7:07
After market has replaceable bushes. Just trying to see if can use stanza shocks in 1200 sedan rear.
#7 Re: stanza rear shocks.
ddgonzal Posted on: 2012/11/1 8:43
Let us know what you find out.
#8 Re: stanza rear shocks.
Posted on: 2012/11/1 11:59
In trying. Its a $200 gamble IM not willing to take dd. The measure mental I have for a 1200 sedan are 30mm wide 30mm high and 12mm hole for bolt. That's the bush sizes in my Monroe gas.
Stanza shocks are 35 wide 35 high with 15mm hole.
IM wondering.If I could trim bush width or replace bush with 1200 one? b210 and b310 list same lower bush as a10 wagon but not sure on sedan
#9 Re: stanza rear shocks.
Posted on: 2012/11/1 13:00
Just checked superpro catalogue. None listed for stanza rear but the same part for both 1200 and 120y b310 gazelle skyline etc
One has 12mm bolt hole,other is 16mm.
I need check mine as says 120y is 16mm. Thought mine were 12?
#10 Re: stanza rear shocks.
ddgonzal Posted on: 2012/11/1 20:05
1200
Bottom mount Nut & Washer
8mm: Coupe
08915-13810 WASHER-lock
08911-13810 NUT
12mm: Sedan,Van,Truck
08911-14210 NUT
08915-14210 WASHER-lock
However they use a special shoulder bolt. The shaft part might be a larger diameter.
