Re: '81 B310 with A12A Canadian brake and strut replacement
Squids, they are available from Nissan, part numbers:
* 56105-H5025 front shock absorber (for Datsun B110)
* 54320-N8200 strut insulator
* 40206-H7500 Rotor (not available from Nissan USA)
Or any Datsun 1200 strut cartridge insert should work. Which is to say there are only a few choices. They need to fit in 45mm struts. See Strut Insert Part Numbers. VW Golf inserts are a popular choice.
Why not just swap the struts over to large-brake B310? You'll get better brakes. Get the entire Strut/Brake assembly from Ralphs, only $45 each side + $18 for the spring. They will increase the front track 30mm (same as a stock A14-powered B310).
One of the best parts shops is rockauto.com. The rotors are getting hard to find. They are the 220mm rotors, only used by CAN A12-powered B310. But they were used outside North America for B210s, so are readily available. Best bet would be to find them within Canada, or mail order from another country.
Posted on: 2013/5/9 2:43
Subject Poster Date
     '81 B310 with A12A Canadian brake and strut replacement Squids 2013/5/8 22:35
       Re: '81 B310 with A12A Canadian brake and strut replacement ddgonzal 2013/5/9 2:43
       Re: '81 B310 with A12A Canadian brake and strut replacement Squids 2013/5/10 20:29
         Re: '81 B310 with A12A Canadian brake and strut replacement Squids 2013/5/10 20:42
           Re: '81 B310 with A12A Canadian brake and strut replacement ddgonzal 2013/5/10 21:37
           Re: '81 B310 with A12A Canadian brake and strut replacement Squids 2013/5/12 18:54
             Re: '81 B310 with A12A Canadian brake and strut replacement Squids 2013/5/12 19:01
               Re: '81 B310 with A12A Canadian brake and strut replacement ddgonzal 2013/5/12 20:08
               Re: '81 B310 with A12A Canadian brake and strut replacement Squids 2013/5/18 8:45
                 Re: '81 B310 with A12A Canadian brake and strut replacement supafatto 2013/5/18 9:01
                 Re: '81 B310 with A12A Canadian brake and strut replacement Squids 2013/5/19 8:44
                   Re: '81 B310 with A12A Canadian brake and strut replacement supafatto 2013/5/19 11:17
       Re: '81 B310 with A12A Canadian brake and strut replacement ddgonzal 2013/5/20 6:41
         Re: '81 B310 with A12A Canadian brake and strut replacement Squids 2013/5/20 8:00
       Re: '81 B310 with A12A Canadian brake and strut replacement supafatto 2013/5/20 9:14
         Re: '81 B310 with A12A Canadian brake and strut replacement Squids 2013/5/23 20:40
