#1 EOI DATSUN 1200 UTE
Ish44k Posted on: 2013/5/9 15:02
EOI white Datsun 1200 ute 1982
Brand new interior
Brand new front end shocks,bushes ,springs steering bigger brakes
Trx wheels 90% rubber
New windscreen
A15 engine twin 40mm DHLA dellorto carburettors,JTS inlet manifold,ram tubes and unifilter socks,custom heat shield/ cold air tray,carter fuel pump
HEAD a15 h89 oval port head,ported,shaved,o-ringed,oversize valves,FIA double valve springs,new seats,stem seals,custom copper head gasket
BLOCK a15 block,decked,bored,honed and o ringed,new welch plugs and arp head studs machined crank & con rods,1mm oversized fly cut pistons,new rings,JTS spec 140 grind dynamic engine balance,king bearings
IGNITION JTS Nissan e15 electronic distributor,8.0mm custom leads and msd blaster coil
EXHAUST JTS 4-2-1 heat wrapped competition extractors,with 2.25" exhaust
CLUTCH 190mm organic exedy heavy duty clutch and 540kg xtreme pressure plate
GEARBOX Toyota 2T alloy split case 5 speed with fellow automotive fitting kit custom tailshaft
PWR radiator
The list goes on the car is in great condition and a lot of time and money has gone into it I'm only thinking about parting with it because another dato I've had my eye on has come up
Sorry to go on and on but this is my pride and joy serious enquiries only and I'll email photos to anyone serious I'm in the Sutherland shire it's not registered please email me with any interest ish44k@hotmail.com I don't really have a figure in mind it owes me well over 22k so no stupid offers cheers
#2 Re: EOI DATSUN 1200 UTE
Ish44k Posted on: 2013/5/10 1:51
Deal fell through keeping the beast
#3 Re: EOI DATSUN 1200 UTE
dat51k Posted on: 2013/5/10 2:13
always good to hear your keepin it mate. get it registered and out and about in the shire. always keen to meet up and go on cruises. even quick meet up down cronulla or a natio run
#4 Re: EOI DATSUN 1200 UTE
Ish44k Posted on: 2013/5/10 2:26
Yeah I e pumped to much into the beast and I wanna turbo it wouldn't know anyone with a turbo set up would ya
#5 Re: EOI DATSUN 1200 UTE
darrenwilson Posted on: 2013/5/11 1:31
Hey could you help me out?
Ihave e15 distributor and i need a pic of how you got the dizzy to bolt to the block
