Browsing this Thread:
1 Anonymous Users
Gearbox Tunnel Sizes |
From South Africa
Hey Gentlemen, I was thinking of acquiring a 63A tranny as I bought my GX with an A15, and I'm uncertain if it was an auto or a manual originally. The tranny's out. - Anyone know what the height and with dimentions are of the manual or the auto tunnels? I'd like to know how much space I need to make the 63 work. . Many Thanks Liebonhardus
Posted on: 2013/6/12 11:10
Re: Gearbox Tunnel Sizes |
Registered Users Contentmaster Usermaster
A15 works great with the 60 series transmission, such as fitted to the B140 bakkie.
The 63A was originally fitted to auto-size tunnels (B210 tunnels). Which is the same size as the 1200 auto tunnel. It may fit in a 1200 manual tunnel with some massaging.
Posted on: 2013/6/13 1:24
From South Africa
Thank You ddgonzal. I'm honestly very pleased to read this. I was afraid I might have had to cut out the tunnel out and duplicate an auto one for this to work. To be totally honest, I'm still exploring options with ratio's and reliability. I scarcely find info on how much abuse gearboxes themselves take. I realize the 63A is quite a bit heavier from the bakkie's 60-series, but I'm afraid the 60 won't last under the abuse I'll put it through. I am definitely going to supercharge the A15 once I've had enough fun with it in N/A form. . On the subject of abuse, do you perhaps know if there's a way I can use the original H145 diff? I keep reading the original diff won't hold up, then again, others say not to underestimate it. I thought of ordering a new gear set and rebuilding it, maybe incorporating shims to even out the grab and wear on the CW&P. Apart from the fact that I'm struggling to find an H165 in good condition locally, the H145 is 10kg lighter, and significantly smaller. . . Thanks once again. Your input is taken with High regard
Posted on: 2013/6/13 7:53
