#1 WANTED A12 PULLEYS
supercharger Posted on: 2013/12/9 3:39
I need standard A12 crank/waterpump/alternator pulleys to size up for GILMER DRIVE KITS. Call 0416080462 ADELAIDE, SOUTH AUSTRALIA.
Thanks
www.keicarshop.com
#2 Re: WANTED A12 PULLEYS
Skremn Posted on: 2013/12/9 5:16
location might help you there buddy.
#3 Re: WANTED A12 PULLEYS
supercharger Posted on: 2013/12/9 6:16
I've just done the drawings for the first water pump pulley. It's for a 1200 long shaft/90mm od and will take 20-30mm wide tooth belt.
#4 Re: WANTED A12 PULLEYS
warner01 Posted on: 2013/12/9 9:25
ive got a crank pully from an a12. im in goolwa beach. if ya want it its yours.
can txt or ring me on 0419699821 if ya want. may also have waterpump pully or you could just measure mine on my car if that helps.
Brendan
#5 Re: WANTED A12 PULLEYS CDI KITS
supercharger Posted on: 2013/12/10 6:14
Thanks for the offer warner01, i have decided to take the pulleys of my honda s600 (has a12 engine conversion)as it wont be seeing the road for a while. Should have the new water pump pulleys next week then i'll continue with the crank/alternator pulleys soon.
The final kit for NA engines with 3 pulleys and belt should be approx $150set.
#6 Re: WANTED A12 PULLEYS CDI KITS
supercharger Posted on: 2013/12/23 4:43
waterpump pulleys have been produced, i have pulleys for alternator and will be doing crank pulleys soon.
jpg  a12wp1.jpg (6.25 KB)
15999_52b7bf4755a1e.jpg 500X504 px
jpg  a12wp2.jpg (6.88 KB)
15999_52b7bf5725ef9.jpg 500X474 px
#7 Re: WANTED A12 PULLEYS
supercharger Posted on: 2013/12/26 5:17
took off my crank pulley today but it has some damage so correct measurements cant be taken.
Does anybody have the crank pulley sizes?
#8 Re: WANTED A12 PULLEYS
thaifrog Posted on: 2014/1/27 12:54
do you still need this information ?
i have an a12 on the floor at the moment so could take measurements..
its a double type pulley...
i would be interested in buying a gilmer drive kit for A15...
#9 Re: WANTED A12 PULLEYS
D Posted on: 2014/1/28 0:04
can send you an a12 crank pulley for cost of postage only if you need
eg. overnight express bag to you, pm me for address
